Qubino modules needs template and detect strange types of modules
I just installed 25 Qubino modules (1 relay, 2 relay, dimmer and pilot) and HC2 says me that there is no templates for these modules… I have read over the Intrenet that since v4 these templates are integrated. My HC2 software is in 4.0.42 version.
More than having no template (I just use manually the bistable parameter for the moment), they actually are detected as inter on/off for one part (correct), temp sensor for one part (correct), and alarm activcator for the two others, or motion sensor for the others in pilot modules… and pilot module is detyected as a dimmer (which permits to choose a level but with no explicit mapping!).
Can you give me the right way to correct that ? Is there a list elsewhere which indicates the level of support of sensors/modules in HC2?
Thanks in advance,
Bruno
Guest chaicka
Not sure where you read that HC2 v4.x includes templates for Qubino modules. Would be interested to find out too as mine are not having template since v4.x3x.
    Thanks for your answer.
    With the time, I think I just dream it
    Fibaro support responds me tos end them the templates in XML files, to be integrated in future version. But I'm not sure it will be done in the near future...
    Bruno
