Hello Guys
I have a motor connected to my Fibaro Roller shutter 2
When I press open or close, sometimes the motor struggles and doesn't act accordingly.
If i press like 4 or 5 times it will move.
Briefly, the order always being received from the motor but it doesn't always move
any idea?
So it is not a z-wave problem :(
    i have uploaded a video
    Switch device to blind without positioning and see if it will move right away or still additional actions will be required.
    Tried this one didn't work
    Take a look at your association group id: 1 and 2
    Empty
    Setup up to Home Center 2 aka 1 for both field
    If motor struggles to move, despite relay switched on (can you hear it going on?) and parameter 18 set to 0 (no positioning/limit switches detection) it is probably some hardware malfunction of Relay Switch or/and motor itself. All module does in this situation is connecting motor to live wire, that is all and should make moto move.
