Scene's stop working, untill you reboot
Anyone have issue's with Scenes in sence that they spontanious stop working? this is the 3rd time now, first time i opened a ticket and before i got a basic answer back from Fibaro (are they enable and set to start with HC2 etc..) release 4.042 came out that day so i updated it and it worked again. beginning of this week they stopped again and a reboot fixed it, now this evening, again they stop working, my garden is dark, so i rebooted it again in the hope it will work again, but this is not the way it should be, want to trust on this device that scene's will run!
7 answers to this question
Code? Is it a scene migrated from v3 to v4?
I think it is the wrong section. @Admins: Please move it to the right section. Thanks
Edited by boomx
Yes, I have that too. I reboot the HC2 two times a day. I'm going to do a factory reset in a month. Let's see if that fixes it (I hope so). Otherwise I'm going to ask support to look at my box.
    I think they are from v3 but also some of them i have already re-created, so i don't think it is related to that. same they are running for some time now end then out of the blue they stop, to me it sounds like a serious bug in v4.
    Is HC fully accessible when this happens? Can you control devices manually from the interface? What is RAM usage when it happens? I would strongly suggest contacting support if recovery does not help.
    I also moved the topic, please note that all technical questions should be posted in Community Support forum.
    For me, the HC is fully accessible when it happens. I can control devices manually from the interface. RAM usage is high. Above 90-95%. I will contact support as soon as I did a factory reset and problem is not solved (because I move to a new house, I will build it up from the beginning
    /emoticons/default_smile.png" alt=":)" srcset="https://forum.fibaro.com/uploads/emoticons/[email protected] 2x" width="20" height="20" /> )
    Hope support can resolve your problem nlwebhosting!
    Yes everything else works fine, also a manual run of the scene or the device will work, i will verify the RAM as soon as it happens again, currently it is working after yesterdays reboot.
    Try saving the scene again and maybe a third time for good measure. I have a very similar problem on v4.042.
    The scene works fine for a while, maybe a day, then it just stops.
    I guess rebooting would fix it (temporarily), but instead I just save the scene once (or twice more for good measure) and it seems to go away permanently.
