kmeta 2
Hello
Some times i need to use switches or sockets to command lights or want to check witch window is open (excluding sensors on door).
For that i make simple scene witch can serach and control devices with have same string in the name.
To use it i for Light i rename all devices (switches, dimmers ... ) to have "Light" in the name etc.
You need to create 3 variables with is using to call scene.
Before you execute the scene you sholud ti set them.
How i use it when alarm system is arm:
