Hi Fibaro,
I will like to know more about the lux update of the motion sensor. Currently I have the parameter 40 set to 20lux. This parameter determines how much the light intensity has to differ from the last value to be reported to the controller. From my point of view, only differences of 20lux in the lux level will be reflected under the event log. However, there are instances where I see a difference of 2 lux was reflected under the event log as well.
May I ask if the motion sensor is breached, does it means it is awake, thus differences of the lux level will be reflected regardless of the lux differences?
Guest chaicka
Reference: Bug 2762 (
    Thanks for the update chaicka
