Global Cache iTach IP2SL TCP/IP to Serial Converter
I have an iTach IP to Serial converter.  I want to send the following HEX string to my CCTV camera.
80 54
If I use this string in the Windows iTest application it works fine. However I'm not sure how to configure the virtual device within Fibaro to send this string as HEX
I have set the virtual device with the same working config in the iTest application.
IP address i.e. 192.168.0.79 and the port number 4999 (labelled serial 1 in the iTest application)
In the string screen I have added -
send 80 54
I have also tried -
send,80,54
But without success.  I can't find any documentation anywhere so any help would be appreciated.
12 answers to this question
Hi Stealth,
You've got the IP/Port right but you should try the following:
Click string (and uncheck Wait for response) and then put:   80 54\r
If that doesn't work try 80 540x0D0x0A
Or 08 540x0D0x0A0x0D0x0A
Usually a matter of trial and error depending on what character return your camera is expecting. Its a eureka moment when you finally get there.....took me two days the first time!!
KR, Dave:)
    Hi Stealth,
    KR, Dave:)
    Thanks Dave,
    No luck.  I tried it as you wrote it without the send option included in the string, removed the wait for response check and still no luck.
    Steve
    Anyone any ideas?
    You could try:
    0x800x20540x0A
    Where 0x20 is for the space in the command. Do not use "wait for response" and reboot the hc2 before trying. I have seen it lockup after several tries, so just reboot to be sure.
    You could try:
    0x800x20540x0A
    Thanks I tried it as you said both with and without the "Wait for Response" checked and with the reboots with no luck.  I'm completely stuck on what else to try.
    I now have the following hex command as the string -
    0x800x54
    I also have "Wait for Response" checked.  If I click on the button the camera moves 180 degs as it should, however if I press the same button again the camera won't move.  (If "Wait for Response" is unchecked then it won't work at all). After one press of the button I have to reboot the HC2 each time for the button to work again.
    If I use “Hercules SETUP utility by HW-group.com”  as a sniffer on the output of the HC2, it looks like the socket is staying open and not being killed after the initial press of the button, I think this maybe my issues?
    Is there a comMand I can append to my hex to close the socket?
    Steve
    You could try :
    0x0D or
    0x0A
    You could try :
    0x0D or
    0x0A
    Thanks I tried these options but still no luck in closing the connection ready for the next command
    Hmm always troubles with these commands.Does the manual say anything about a specific command format ? For example: command + linefeed?
    No I think its a Fibaro issue as it work fine using the Global Cache iTest software.  The manual states the following -
    The command: 'turn 180 degrees' is a two byte command and has no parameters.
    1st byte.     'camera address'
    2nd byte.    54h Turn
    This command has no reply.
    Looks like it's not possible at the moment. For some reason Fibaro won't close the socket for the resend command.  The workaround is to manually code the TCP/IP socket in the Virtual Device window as Lua code.  This is working for me -
    "IPAddress" and "TCPPort" is inputted on the front general screen page of the Virtual Device
    and 80 and 54 are my two hex bytes I needed to send.
    Steve
    Guest andyhud
    Hi Steve
    Old post I know but I've just got a second hand iTach Ethernet > Serial box that I want to hook upto my Epson projector which has a serial input
    Is this problem still applicable where the Fibaro won't drop the command. So if I send a Turn on command over serial, I may not be able to change the HDMI input on the projector because the previous command hasn't dropped?
    Or do I need to put each command into a VD like your last post above?
    Andy
