Hi guys
I'd like to configure my fibaro motion sensor to exclude my pet presence (around 35 kg)
Has anyone configure the sensor in this way? Could you please post the parameters .
Thanks in advanced
Gustavo
Guest azevenhuizen
    Dear All
    The Offical response from Fibaro....
    I've started change the (parameter 1) to 50...
    I will keep you update
    Waldemar Kin
    Dear Sir,
    You can try change sensitivity of Motion Sensor by parameters 1 , 2, 3 and 4,
    but I am not sure this will help with such big pet.
    If you will have any additional questions please feel free to ask us!
    Don't know if there is any motion detection device that can exclude an animal that big? My burgler alarm sales man (not zwave) told me they could exclude up to 20kg aprox. If noting else works try to make sure the motion detector can't se the floor by raising it or add a piece of tape to blind it from the angels you don't want it to see.
    Or else just let the pet turn the lights on and off, will work just as good as a pressens simulator.
    35 kg indeed is quite a lot, for example Satel usually provides sensors that can ignore pets up to 20 kg.
    OK
    So, Do you have the right parameters for 20 kg pets?
    Many thanks
    My old alarm company' sensors was promised pet immune for up to 25kg.
