Simple LUA to to show which sensor has been breached
Unfortunatelly on mobile app. in case of Alarm you cant see which sensor has been breached, therefore Id like to create simple LUA scene which would be triggered by Alarm to send info which sensor has been breached - any idea how to create it pls ?
Thanks in advance
7 answers to this question
Check if which sensor is breached when arm
Thanks in advance
On iOS ?  .. you can click on the beacon icon or strobe icon and it tells you which sensor has breached on the alarm page of the app.
Cheers,
al.
I want to see the name of the triggering sensor in a Lua script when a sensor is breached..
But I cannot find it anywhere on this forum. This topic is the one with the specific question in it.
Can someone help me out?
    Im using something like this - checking one by one which sensor is breached...
    if
     ( (tonumber(fibaro:getValue(38, "value")) > 0 and tonumber(fibaro:getValue(38, "armed")) > 0))
    then
        fibaro:call(213, "sendPush", "Alarm Activated, Motion in Livingroom detected" )
    if
     ( (tonumber(fibaro:getValue(18, "value")) > 0 and tonumber(fibaro:getValue(18, "armed")) > 0))
    then
        fibaro:call(213, "sendPush", "Alarm Activated, Motion in Bedroom detected" )
    if
     ( (tonumber(fibaro:getValue(22, "value")) > 0 and tonumber(fibaro:getValue(22, "armed")) > 0))
    then
    Thnx Acho!
    Maybe I'll use your method of no one else can help me. I know there should be a way to get the name of the triggering device.
    There is an easy way of getting the triggering device:
    Thanks Rait. It works perfectly.
