Philips Hue not visible in grafic blocks scenes
I want to use the standard fibaro add in and not a virtuel switch script for philips Hue .
In the grafic blocks the Philips hue lamps are not visible.
In the LUA code engine they are vissible but I cannot manage to set de brightness level.
I only can send the commands "on, of, volume and mute"
The volume and mute options do noting.
Can someone help me with the fibaro code to set the brightnes level of a led lamp?
Robert
Take a look at Fibaro Bugzilla -
Make a comment. Possibly a change is made faster on the HUE Plugin. I wait for a solution too.
made a report
i also use hue lights and know i am not able to turn the lights on or off by motion sensor
