ZME_RC@ controller read input of buttons
I want to read the value of the buttons 1 to 7 of the remote controller and use them to send signals to other devices.
With a script I can read the values of the three "scene" buttons  with the fibaro:getValue(61, "sceneActivation") function.
The values are 81 82 91 92 101 and 102
What I want is with another function to read the input of the buttons 1 to 7 so i can use these values to send an command to a scene or device.
Maybe someone knows the values of button 1 to 7
They have on and of and dim functions with their specific codes.
Help is much appreciated.
Robert
You can create a little lua script like this and then perform all the actions:
This will tell you the exact values (don't own the remote so I cannot tell you otherwise).
    Remko,
    Tahnks for your reply.
    I tried it but it gives me a nill value.
    I used the following script to test it:
    %% properties
    61 sceneActivation
    61 value
    %% globals
    myVariable2 = fibaro:getValue(61, "value")
    myVariable =   fibaro:getValue(61, "sceneActivation")
    fibaro:debug ( "value="..myVariable);
    fibaro:debug ( "value="..myVariable2);
    After debug it gives me the message:
    [DEBUG] 16:51:09: value=81 (with the 61 sceneActivation array)
    [ERROR] 16:51:09: line 12: attempt to concatenate global 'myVariable2' (a nil value) (with the 61 value array)
    If I press the button 1 to 7 the script does not give me any return information.
    Only the buttons for the scene (three buttons) give me the above result.
    Any other thoughts?
    Robert
