energy consumption
is it just me or disappears the energy consumption each time the chart. now i have only from may 13 at 12:00 o'clock
20 answers to this question
After a restart of the HC2? Or while the HC2 is running?
    while yhe HC2 is running
    just did a restart and a total on of HC2
    still energyconsumption from 13 may 12:00
    but i know over one week or two its disapears again
    Mhm. There was a bug, that the energy consumption blows away after a restart. But this should be fixed with 4.042. Seems like another bug
    There was indeed problem with saving this kind of data to database but it was solved. Make sure you have latest firmware.
    Ik do have the latest firmware
    4.042
    That is strange, HC2 can store quite big amount of data, unless you have a lot of energy metering devices with constant reporting, it should be ok. Are latest events displayed properly? Do I understand correctly, that there is no history before 123 may, but right now it works fine?
    the first measerment is 13 May at 12:00
    the temp is first at 27 March
    Same here (4.042) and I have only data from the beginning of may, the rest is gone.
    Will Fibaro develop a Humidity Panel to graphically display changes in humidity as well?
    Please determine how many records are there in system, or even roughly estimate this, so we can know if it is possible that maximum number of them were reached.
    As for Humidity Panel: I will pass this suggestion further.
    I don't now if this is what you mean, But i have 19 devices that measurs the energyconsumtion.
    If you mean the total counts of every devices for measurment the energylevel......WOW
    That is al lot
    only for my homecinema i have a day count of 250 plus
    That is al lot
    It might be too big amount of data to handle, I already gave our developers know about these problems, they will make revision of code that is responsible for storing these values and restricts its number.
    Thanks, thanks and thanks
    Guest chaicka
    The bug has not been solved. I posted a regression bug
    and it has not been worked on since weeks ago.
    I faced this bug before 4.042 and after upgrade to 4.042.
    Guest chaicka
    I only have 2 devices that measures power consumption. Surely that cannot be a case of too big amount of data for HC2 to handle.
    1 x Aeon Lab Smart Switch Gen 5
    1 x Qubino Flush 1 Relay
    I got some response from fibaro;
    they say;
    Number of energy consumption reports is limited in our system.
    Our HC2 can store 50 000 reports about energy consumption and 25 000 reports
    about events – probably you should decrease number of reports from your devices.
    My home cinema reports in one year about 93000 counts
    everytime the energy change it reports!
    they say;
    We are currently considering to extend number of data that can be stored, since in some installations it indeed was too little.
    In my HCL (4.054) after restart of HCL, measures power consumption data is gone (empty, 0 value). But the temperature measure is still present. What is the difference?
    I am just start the testing with one WallPlug in one week, it can't be so many data.
    I have the same problem with Home Center Lite and only using 3 relays from two thermostats.
    4 years later, and the problem is still here. I don't think Fibaro will ever fix this issue.
