Have anyone here tried to connect a power supply to a motion detector or other battery device from fibaro ?
i am tired of changing batteries so often...
In principle this should work if you do use the correct current. The diameter of the cable could be quite small due to the limited consumption of the devices. But how often do you have to change batteries?
i connected a 3 volt powersupply to a Fibaro motion detector.
works fine
    Well it seems that i am replacing the batteries very often, but i have the devices set up in a power consuming way.
    So going to give it a try
    Tnx
