Hi Guys,
Probably a simple one, but I just can't see where to do it.
I paired a Fibaro Motion Eye last night and it keeps intermittently flashing green. Firstly, why is it doing this? Secondly, How can I turn off all LED's on it?
thanks guys
Its flashing when movement is detected, default colour is in relation to the temperature, eg flash blue would be cold, red hot etc, so green means its average sort of temperature.
If you go to the advanced settings for the device, parameter 80 controls this.
Dont forget once this parameter is changed you will have to wait for the device to wake up before settings saved on device (or wake it up manually)
You seem to lack the manual for this device. A replacement can be downloaded from
    Thanks Guys,
    I do lack the manual, had them for a while out of the box so have misplaced them.
    I did change parameter 80, but it still occurred, maybe I just need to be patient for a wake.
    Just click "B"  button like during inclusion process. New setting should be set then.
