Change Color of text/buttons in Virtual Device
Hi Fibaro,
Is changing color of text/buttons applicable in virtual device in the latest v4?
I've seen several examples using this statement to debug colored text.
string.format('<%s style="color:%s;">%s</%s>', "span", "red", "text", "span")
I tried this in a virtual device. Initially the text appeared will be : <span style="color:red;">text</span>
until i refresh the browser and it will be changed. Any simple ways to use this?
no and if it would work it is only visible in your browser, as soon as you would open the app the whole text: <span style="color:red;">text</span> Would be visible.
(I tried
/emoticons/default_wink.png" alt=";)" srcset="https://forum.fibaro.com/uploads/emoticons/[email protected] 2x" width="20" height="20" /> )
