perform device action from php script
Guest reiniertc
when I test the api in my webbrowser with this url:
the light turns on.
But when I use the same url in a curl command from a php script, nothing happens.
also: when I try to use the URL from a javascript: no luck.
Can anyone help me with an explanation/example on how to perform a deviceaction from a webpage using the API?
Attach authorization as a header, encoded with base64, this will do.
Perform HTTP GET request on that link (in v3) or POST one (v4).
Guest reiniertc
    Thanks. I'm running on v4, but when I issue a Post request, I keep getting a username/password prompt
