dw89 8
Hi All,
I did the same with POP_123665 switches (I have two; one for Fridge and one for Freezer) and, like TKB88E (which definitely doesn't work) these didn't either (i.e. no energy reporting).
I did a backup and then did a soft-reconfigure and, like TKB, got three children. I set first two parameters to 1 and 10 to see if it brought back readings and it does! Also, all children work. So, just so hope that helps anyone know what to do. Only annoying thing...again, is that both W and kWh have been moved to first child [Voltage again] and not on master binary switch.
Only question is what are the other children? Unlike the TKB there's no notations? First is obviously Voltage but what are second and third? Current perhaps for second i.e. [A]? I don't know. Any help on this Fibaro please.
KR, Dave:)
PS I will temper this with the fact that current wattage (W) is 100% working (and Total kWh seems to be too) but the last two children just have figures, which aren't currently showing update....so time will tell and I will report back!
PPS Update....the three children are the same as TKB's i.e. 1] Voltage 2] Amps 3] Power Factor. ONLY problem is, again, the location of the W/kWh reporting (on Voltage child). It shows up in energy panel but, in iOS (iPad) it only shows voltage and NO 'consumption' values at all (w and kWh) like it used to on the master. And the master binary switch shows 'Consumption=0'. Either Fibaro need to put consumption on the Voltage child and remove 'Consumption' from Master OR put it back on Master in first place. Apart from that this switch works well.
PPPS Finally, in voltage child (as you can only get from here) to get Voltage you need to use 'value' property in lua, if you want Watts, you need to use 'power' property in lua and for total Wattage over time you need to use 'energy' property in Lua. Hope that helps
/emoticons/default_icon_biggrin.gif" alt=":-D" /> Edited by dw893 answers to this question
