Scene Activation Upgrade
Please add Double click trigger to Input S2 in case of Roller blind switch mode
double click ID 24 (depends of parameter 15 value 1 - double click functionality)
all lights in house connected to roller blind switch and i want to double click on UP&DOWN TurnOn or TurnOff all lights in RoomID and Triple click TurnON or Off all lights in SectionID but i missed the double click event in S2
and if possible add Scene Activation to RGBW modules & Relay Modules
As you noticed it is only mistake in manual and double click triggers scene activation id 24. Implementation of this feature in other modules (RGBW, Switches) depends on module itself and will be introduced in future revisions of the modules.
    Dear j.nowacki
    it's not the manual mistake, it really not trigger any scene activation id if you set your dimmer module to roller blind switch mode and double click S2(down) switch !!??
    it really annoying because recently i replaced all of my tree floor switches to roller blind and i can't get the result i want.
    i'm very thankful if you resolve this issue.
    Dear j.nowacki
    You did not mention about the device being Dimmer, just the Roller blind, so I assumed you meant Roller Shutter 2 which also has this functionality and misses proper information about it in manual.
    Regarding Dimmer: there is no option to trigger scene with double- click in this mode, it is a device thing and can not be changed with some update of controller. You can use ordinary momentary switch mode with these switches as well and adapt your scenes to it.
