Chrisvr2 0
I have the following situation:
The lamp in the living room have to turn on when the wall plug uses more than 100w and the time is between sunset and sunrise.
This works fine, lamp turn on and off if criteria is not matched.
This way, if I turn on the TV and hifi, the lamps turn on. And off if I switch the TV off.
I would like to be able to switch on the lights manually and keep them on, even when the TV is off.
But only if they are switched on manually. With my current script, they will be turned off if the TV is off.
Anyone any idea how to do this?
