Hi all
Trying to add a temperature sensor to the Fibaro RGB.
I have changed the controlled device to output/input and selected temperature sensor.
After I saved and device reloaded the icon changed.
How do I configure to see temperature?
Attached screenshots and photo of installation
Is it DS18B20? RGBW uses analog sensors, DS18B20 is digital one, with 1-wire bus. And you unfortunately damaged it probably by connecting to 12V (it is 5,5V max) on the wrong pins (GND and data pin).
    Yes its DS18B20. I totally forgot the check the voltage!
    RGB still working fine after removing DS18B20
    Ok thanks which analog sensor would you suggest?
    Any with passive 0-10V output should do.
    SCS, please write results of your experiments, when achieve success:
    1. Model of sensor you will find
    2. Picture of pluging and configuration
    3. Result in GUI
    Thanks)
