erip-eri 0
How can I connect a so called "pull down" output (from a wired alarm system, Scantronic 9751) to Fibaro. This output is normally used for a strobe (and not in use) and I want to connect it to Fibaro in such way that I can get a push message when the alarm is triggered. I do have door sensors and a universal input module that i can use but I do not knwo which one and how to use it. And I do not want to experiment to much because I don't want to break the alarm.
The outputs are described as: Open collector transistor outputs, 500ma, 12vdc, negative applied.
thanks,
Eric
