Hello, I am planing to put Fibaro devices in my company. I already have about 100+ switches in my houses. I wonder would it work fine if two HC2's in same network ?
4 answers to this question
Different Zwave network. 2 separate IP.
Should be able to work. Any clarifications from Fibaro?
You must use the gateway function but with two HC2 loaded with V4.XX
You can use gateway connection feature, but it will create 2 separate Z-wave networks that should not interfere with each other. You will be able to manage them as one.
    Can you please answer something also regarding this ?
