dirkies 1
I just discovered something odd with my HCL scene setups:
when you set a scene to raise a shutter but then stop it after let's say 6 seconds (in my case because my shutter engine is not allowing the Fibaro module to calibrate), it works fine.
But when I add a second shutter to the same scene and same line, both shutters will go up at the same time, but stop also both after 3 seconds!
I did another test with THREE shutters in the same line, and guess what, now all 3 stop after 2 seconds of opening...
So is this a bug when putting multiple devices in the same line, that the delay is divided by the amount of devices it applies to?
4 answers to this question
