Y-cam 1080HD
Appiedellah
Gents,
I have a question.
i'm running into a problem during the implementation of the Y-cam into the Homecenter 2.
I already put the ipadress in the advanced settings and also the cgi, but still no picture.
hopefully somebody can help me out of this
attached are some pictures of the settings i use with the ipcam and Homecenter 2
thank u
9 answers to this question
  • All,
    the issue has been fixed by changing  jpg url and mpeg url into snapshot.jpg and stream.jpg. I copy/paste the url from the ipcamera stream setup (192.168.x.x) but this seems not working.
    Thank you all for you time and help.
    jpeg path: snapshot.jpg
    mpeg stream path: stream.jpg
  • Hi boerremk,
    I did copy those streams into the homecenter but stil no sign of à live view.
    Anybody Some suggestions For this issue ?
    I have the same thing sometimes. When I reboot my camera, it will shows the picture.
    Give it a try.
    You also need the portnumber behind the ip address:
    192.168.x.x:80
    80 is default port number.
    I don't have to add the portnumber. So if it is running on port 80, it should work.
    I use a different port...
    @Appiedellah: could you paste your settings again?
    Howzit I'm having some issues adding a Ubiquiti UniFi Cam to my HC2 is it supported?
    Any suggestions would be highly appreciated
