Virtual device icon for main power button..
Dear Member,
I have created a virtual device with one button.. this button switches my plugwise wall plug on and off.
This works flawless.
The problem is that the main button (under devices) won't change color blue when activated just like a normal existing switch.
(on/off button won't change color)
(Example blue button from existing switch)
What code do i use to update the main on/off button?
Below my current code..
%% properties
%% globals
-- Get the value of the 'status' global variable
local value = fibaro:getGlobalValue("plugwise1")
if (value == '0') then
plugwise = Net.FHttp("192.168.1.2", 80)
plugwise:setBasicAuthentication("stretch", "sgxfzdxj")
response = plugwise:POST("/minirest/appliances;id=b601b5816f0743a5b111bda80787ab19/power_state=on", "\n\r")
fibaro:log(response)
  fibaro:sleep(1000)
  fibaro:setGlobal("plugwise1", "1")
else
response = plugwise:POST("/minirest/appliances;id=b601b5816f0743a5b111bda80787ab19/power_state=off", "\n\r")
  fibaro:sleep(1000)
  fibaro:setGlobal("plugwise1", "0")
Thank you for your time!!
br
Vincent
4 answers to this question
You are comparing virtual devices and plugins, two completely different things. There is no way to keep the button blue in virtual device, however you can change the icon depending on a state of device.
Hello
How do I get a virtual device to change icon? I have a Denon virtual device, however I can only chose 1 icon when I click on the change icon button.
Thanks!
Guest spazpeker
something like this, you need to change the icon 1004 & 1003 to values of the icons you want
local vdID = fibaro:getSelfId()
-- ID of switch
local S1ID = "your device id
local status1 = tonumber(fibaro:getValue(S1ID, "value"));
if ( tonumber(status1) > 0)
  then
fibaro:call(vdID, "setProperty", "currentIcon", 1004);
else
fibaro:call(vdID, "setProperty", "currentIcon", 1003);
Edited by spazpeker
Thank you spazpeker!!
