How to use "XXm before sunset" trigger
I'm using 4.042 with HC2 and in version 4.x a new time trigger  is available for configuring scenes. In version 3.x you could just set the time to sunset or some predefined minutes options after sunset. In version 4.x you can also select "XXm before sunset", but I cannot find how to define the number of minutes to use.
Any help on this?
6 answers to this question
Just put them in a box next to the drop list. Also note, that, this is not proper forum for questions, I moved your topic.
    There is no box next to the drop list, otherwise it was easy.
    Just performed the update to 4.048, but still the same.
    So I assume it looks different than here?
    What browser is it?
    See attachment for my display box. I'm using the Dutch language and tried it in Chrome as well as in Firefox and Safari (working on MAC OSX). All the same result.
    This was an existing scene already in v3.600. I then removed the box and added it again to the same scene and it works!
    So the conversion of old scene failed, will take not for the future.
