Q: Filter to show only active scenes ?
 Is there a clever way to filter scenes so only the currently active, or even just those marked active can be shown ?
Without all my broken, test and inactive scenes in between ..
A little status indicator on the overview screen of the scenes would be a bloody ripper I reckon ..
Thanks in advance,
al.
7 answers to this question
if you go into the dasboard you can see which scenes are currently active.
I've got this script that prints:
I hope you can adapt it to your needs... There's only one for loop and that's where it all happens... Add for example property "runningInstances" if you want to see the, er, number of running instances
Well I use a simpler method. Put the active ones in one room and the test, broken and half finished non running ones in another room. It will not show which ones that are running but it helps to know witch ones that are supposed to run and which are not. And I also start every scene with a printout "scene running" so that I can check if I forgot to start it or not.
    @petergebruers,@Joacim,@stevenvd .. Genius ! all of you !
    I usually use Krik's HC2 Toolkit, these are way better ways to do things if I'm not at home !
    Cheers for the script, I'll definitely have a play,
    organising the storage into areas, is a very elegant solution,
    and seriously, is the dashboard working again !!??
    /emoticons/default_smile.png" alt=":)" srcset="https://forum.fibaro.com/uploads/emoticons/[email protected] 2x" width="20" height="20" /> excellent !
    Cheers,
    al.
    I cant get my dashboard to work. Below is what I get if I try to modify it. If I open a few then close the dashboard they are gone when I reopen it.
    Brian
    Brian
    Hi Brian, mine is kind of the same, I don't get the error you do .. I can do a general selection and add that then I get them showing, but then I can't get out of the dashboard, without going back to the IP and also they are all gone when I do revisit. I stick to HC2 toolkit now, it's the most reliable for me, although the lua script works well, as does the dashboard, albeit intermittently for the visit I am there !
    cheers,
    al.
