I want to use window break sensor connect to my door window sensor, but D/W sensor does not accept any input when it's magnet is close!?
how can i send signal through IN terminal of D/W sensor when it's magnet is close and the window is closed???
I already test changing parameter 3 and sceneActivation with no luck when magnet is close.
The terminals of the D/W Sensor are parallel to the builtin reed relay. They are not separate inputs to the processing part of the sensor. I'm afraid that what you want can't be done with a single D/W sensor. A "Universal Binary Sensor" has two separate inputs, but it's mains powered. I hope this explains...
