I tried to install roller shutter module on Selve motorized blinds but the only thing that happens is that blinds move up or down for 10cm when you press pushbutton.
The problem is we still don't have Home center 2 installed, but only modules. However I tried to run calibration by pressing 3x3sec button UP (or down). Calibration starts and blind starts to move up, but stops after 20cm and then goes full down. There it stops and does not move anymore. After that, same situation with 10 cm up/down movement.
Does anyone have any hint or solution for the problem?
Kind regards and thank you!
This is probably effect of too low power drained considered as limit switch, parameter 18. There is no way to adjust it without controller of any kind to send new parameter.
    Thanks for answer.
    Could you please explain what has to be changed to work properly?
    Parameter No.18 means what and how I can change him?
    You will need a home center to check for the solution.
    Parameter 18
    Motor operation detection.Power threshold to be interpreted as reaching a limit switch.
    And see the post von MalvinYNJ.
    How to change it. To lower on higher?
    same problem to me (I've just opened a new post), how many wire does your motor have? 4 or 5 wires?
    It probably cannot sense power consuption...
    Set 18 to 0 and see how much power is drained when blind is moving and how much after stop. Then set it to value slightly higher than the value after blind stops.
