I've connected to my sunshade the roller shutter 2 module, but it cannot calibrate because the motor consuption is only 0.7 w costantly!!
My roller shutter motor is not like normal...it has 5 wires!  (earth - live - neutral - up - down)
I think that probably there is not consuption between neutral and up/down wires, because they only send signal...and the consuption will be between live and neutral!!
Any suggestion about connecting it correctly??
It looks like your motor has some kind of driver already build-in,most likely there is no way to enable positioning, since Roller Shutter is designed to work with motors without driver.
