Minimote dimmer functionality
Guest lhusoey
Im trying to control a dimmable light with my minimote remote.
I have made a virtual device called minimote so that i can program each of the eight buttons the minimote holds.
I have managed to swith on the light using this LUA code for button 1 : fibaro:call(40, "setValue", "70");
Also for switching off i use the LUA code for button 3 : fibaro:call(40, "setValue", "0");
Now what i want to do is as follow.
Increase lightstrenght by using button 2. ex stepwise increase by 5% each second or so the button 2 is pressed.
Decrease lightstrenght by using button 3. ex stepwise decrease by 5% each second or so the button 3 is pressed.
Can anybody help me with the LUA codes needed for this to function?
Best regards
Lidvar
HC2 v4.048
4 answers to this question
I don't think you can do that (using sceneActivation)... It's been asked here before. It's because, if I remember well, you can't detect when the button is released. I settled for a workaround: each button press increases the level with +/- 20 % so yo get 5 steps from 0 to 100% and back to zero. You can also implement "off" as long press. WAF (Wife Acceptance Factor) = OK.
This is the code in the "button press" part of your logic:
Guest SPyRoX
    Many thanks for this one petergebruers!
    You're welcome!
    Hi all,
    Very interesting this post!
    I use a minimote with a virtual device. The VD pilots a Hue lamp. In this VD, I have different buttons which change the Hue color:
    Button 1: red color;  Button 2: orange color ...
    I'd like to associate one button of the minimote, with 6 different colors.
    If button 1 is pressed then red color
    if button 1 is once more pressed then color orange ...
    What i have now:
    VDid: Virtual device id
    VD button "1" gives red color
    ... how could i code to get the same minimote button with 6 differents colors ?
    Thanks  for your help !
