I can not  set a main thermostat in the rooms. I have make a thermostat whith linked device panel. When i set in the room the main thermostat in the menu appears there are no sensor of this type in the room. Any idea?
Linked device is assigned to room and gets setpoints from panels, but it is not visible in interface, that is the way it was designed.
