nadigo 0
I would like to send fibaro a value (1-255) to store on a local variable so I can later access via LUA
as there a way to send such value to fibaro ?
I didn't found any API call for this, the only thing I found which look close is to set a slider value of a virtual device via API
any idea ?
if no other idea, can someone set the code to use virtual device for this (and also how to call its value after via LUA)
thanks
Nadav
