i have made a scene to change variable from sunrise to sunset.....
At sunrise--------   change variable to day
At sunset -------- change variable to Night
i googled my location and found out that the sunset time was at 20:02   ......
time went by and at 20:40 the variable did not change......
as soon as i put in scene 30 minutes before sunset change variable .....
the variable state changed
so my guess is that there is something wrong with my location
what is the proper way to set my current location in settings???
i have put my location using longtitude and lattitude
using format XX.XXXXXXXX
is this right ??
Regards
Christos
7 answers to this question
is your location (long&lat) based on the exact gps location or is a general (country) type of long&lat?
    Hello
    I have put my Logt&Lat Based on exact GPS location
    Today i woke up And all my night lights were still ON
    When i Opened HC2 Interface in Variable Panel i see that the TimeOfDay Varible is still Showing Night.....
    So there must be something Preventing the variable from changins state OR my Location is giving wrong triggers ....IF it gives
    Christos
    Can you check your daylight timing on your hc2? Check if its the same for your location. likewise you can try putting your log&lat based on your country( general ).
    hope it helps.
    This is the location Tab..... as you can see there is one hour difference between my current time and the time showing in HC2 Location settings....
    But at the top right corner where the weather is showing ... time is correct....
    how can i check my daylight timing ??
    or anything wrong with this scene ???
    christos
    Did you mark the boxes, "starts when hc:2 starts" and active scen?
    Hello
    Yes all boxes are checked
    Use this long&lat 35.16666733.366667 and make sure that your time is correct first before checking if the daylight is correct.
