Simple Timer - LUA
      can you pls support on how to create a simple VD which would switch off a device after defiend time, which would be set by the buttons "+" and "-" directly in the VD ? Or any ready made solution available I could easily modify ?
Thanks for help
9 answers to this question
I attach simple example, to count down from given value - just add action for device to the button, i kept it really simple, so no protection against running it 2 times etc.
    great, will try, thanks a lot
    Im getting error message in debug, btw how to implement multiple running protection and where to place the device to be switched off after defined time pls ?
    [ERROR] 16:27:01: line getSelfId()..."]:5
     EDIT: error was related to not defined time, so my fault, how about the multiple running protection please ?
    And one more - Ild like to have half an hour ( + ) feature, showing then the countdown HH:MM
    I would check if first label is not 0 and do not enter the loop on that basis.
    correct, the "0" was the issue, but how to avoid its running multiple times please ?
    anyone can help how to avoid it will run twice if by chance activted twice ?
    Thanks a lot
    I was talking about the protection against 2nd run. I attach changed device.
    Great, thanks a lot for support !
    How can we use the timer?
