Little presentation and unboxing Heat it Thermostat
Guest Paweł Świerczyński
We tested nice Zwave thermostat by Heat it :
Functionality:
• Room sensor
• Floor sensor
• Temperature limiter
• Power regulator
• Z-Wave chip 500 series
• Weekly program via gateway
• Setback mode via gateway or pilot wire
• 7-segment LCD-screen
• Can be used in connection with different NTC-sensors
• Lock mode/child lock
• Backlight
• Calibration
• 8 scenarios
Presentation below:
Thank you for this vidéo.
The real questions is when this device will be integrate in the heating panel by fibaro ?
Sure its nice! Nut not functional.
- No config template
- No possible to set target temp from iOS or Web
- Actual temp not shown correctly
    Hmm strange , we tested Heat it with home center 2 , and it works perfectly besides one think with we are waitting .
    Thermostat work in two way : with no HC, cable connection with stove only on/off, and with HC than we  can make temperature schedule.
    Of course we can control heating by app.
    One think with is  most important think
    /emoticons/default_smile.png" alt=":)" srcset="https://forum.fibaro.com/uploads/emoticons/[email protected] 2x" width="20" height="20" /> we are waitting  for  manual control when we have temperature schedule.
    If we have temerature schedule and we want to change temperature manual its change for 5 sec and back to temp schedule(  ist bad solution of course but support told me that the change it and will be the same solution like on SRT thermostat )
    If support change it we can change manualy temperature,  and we have manual temp for 2 hours, after that system get back to temp schedule.
    Looks interersting, but where i can buy it?
    please conact with me on my mail: [email protected]
