Why does this scene not work. Email alert multiple times.
Hi.. I am using the following block scene to see if the weather outside is Rain or Storm and if so, it should set a delay of 24hours in the sprinkler panel. However, when it should run, it should only run at 12:00 mid day once. However, when it did run, it ended up sending out over a 1000 email alerts to me. So I turned off the scene.
What am I doing wrong???
8 answers to this question
Try to uncheck the triggers
    Ahh. Thanks. Totally missed that!!!!!
    No problem
    What is the use of the "triggers"?
    What can they control ?
    I believe in my scene, the 3 triggers are the Global Variable, Weather and the time. So if either of the components had a change in condition, it will trigger the scene. So if I wanted to trigger the scene alone on time then to deselect the Weather and Global variable trigger should only trigger on time.
    Well, that is my understanding..
    OK.. Unchecked those 2 triggers and then set it running. Yesterday, we had rain forecast and the scene again sent me around 40 or so messages around 2PM before I termnated the scene.. so that didn't fix it.. pretty confused as to why it keeps running past the 12:00 as I want it to run only at 12:00.
    I presume it is your use of "or" and how that plays into the rest of and statements, specifically rain versus the sprinkler delay. It is a different topic here on the forum addressing nesting like you have done, sometimes it plays out different than you expected.
    Try to convert it to lua and check if the logics int the statements then become more obvious.
    This is the code converted to LUA.
    %% properties
    %% globals
    local sourceTrigger = fibaro:getSourceTrigger();
    function tempFunc()
    if (
     ( fibaro:getValue(3, "WeatherConditionConverted") == "rain" )
    or
     ( fibaro:getValue(3, "WeatherConditionConverted") == "storm" )
    and
     ( tonumber(fibaro:getGlobalValue("sprinklerdelay")) ~= tonumber("0")  and  ((currentDate.day == 1 or currentDate.day == 2 or currentDate.day == 3 or currentDate.day == 4 or currentDate.day == 5 or currentDate.day == 6 or currentDate.day == 7) and string.format("%02d", currentDate.hour) .. ":" .. string.format("%02d", currentDate.min) == "12:00") )
    then
        fibaro:call(319, "pressButton", "2");
        fibaro:setGlobal("sprinklerdelay", "0");
        fibaro:call(13, "sendDefinedEmailNotification", "325");
    setTimeout(tempFunc, 60*1000)
    if (sourceTrigger["type"] == "autostart") then
    tempFunc()
    else
    if (
    or
    and
     ( tonumber(fibaro:getGlobalValue("sprinklerdelay")) ~= tonumber("0")  and  (currentDate.day == 1 or currentDate.day == 2 or currentDate.day == 3 or currentDate.day == 4 or currentDate.day == 5 or currentDate.day == 6 or currentDate.day == 7) )
    or
    then
