Heating panel don't work!
Hi.
I have a problem with a heating panel.
It is set up properly, but it do not write temps the danfoss living thermostats. (in the web interface I can see that temps are constant, the connection to thermostats is ok).
It did work for a while until I put the system in holiday mode and back again.
Now temps is not updated
Anyone have a workaround this firmware bug, or system error??
9 answers to this question
Is it HCL or HC2? We are looking into heating panel feature right now, since it seems to be causing some issues in several installations.
    It is HCL.
    Software Version:3.594
    OK, we will take a look on that.
    Thanks.
    Right now mine is in a state where temps are not updated.
    I know that if I delete the heating panel and make a new one, it will work until I bring it in manuel or holiday mode.
    Dont know if it will be helpful, but you are welcome to have a look in mine HCL.
    I will let you know if we will need to take a look at your system, thank you for the offer.
    Is there a time estimate for a fix/update?
    In one of soonest updates, but we do not have timelines for that, it depends on result of tests.
