Hi
I am trying to figure out how to send myself a push when the iron (connected to wall plug) is consuming power (say more than 2W) for more than 30 minutes. This will mean that I probably forgot to turn it off
/emoticons/default_smile.png" alt=":)" srcset="https://forum.fibaro.com/uploads/emoticons/[email protected] 2x" width="20" height="20" /> I would like to be notified after 30 mins and then every 5 minutes. But I just cannot figure that out in LUA. Can you help?
13 answers to this question
Nice idea... Ok, I will code something
    thanks, appreciated
    So... Can you test it please?
    /emoticons/default_smile.png" alt=":)" srcset="https://forum.fibaro.com/uploads/emoticons/[email protected] 2x" width="20" height="20" /> I only made a test with shorter times. It works for me. You have to change the trigger, the wallplug-ID and the ID's of your phone.
    How do I find the ID of my phone?
    Do have to add it as a virtual device?
    This is a scene, which is triggered by status-change of your wall plug.
    You can find your ID over
     Here you can search for your phone-name. It looks like that:
    • "id": 68,
    • "name": "iPhone 6",
    • "roomID": 0,
    • "type": "iOS_device",
    • "baseType": "",
    • "enabled": true,
    • "visible": true,
    • "isPlugin": false,
    • "parentId": 0,
    • "remoteGatewayId": 0,
    • "viewXml": false,
    • "configXml": false,
    • "interfaces": [ ],
    • "properties": {
      • "DeviceToken": "d37ef4************************************",
      • "DeviceUID": "44606C04********",
      • "Push": "true",
      • "deviceIcon": "91"
    • "actions": {
      • "sendDefinedPushNotification": 1,
      • "sendPush": 1
    • "created": 1434562121,
    • "modified": 1434562121,
    • "sortOrder": 64
    thanks, testing now
    code is very good thanks. You did not declare power though
    /emoticons/default_smile.png" alt=":)" srcset="https://forum.fibaro.com/uploads/emoticons/[email protected] 2x" width="20" height="20" /> Fixed that. And also modified your code to abort scene and used "power" rather than "value" so that i do not have to turn off the plug, just unplug the iron
    Guest fat
    Would you be able to post your modified code please?
    %% properties
    500 power
    %% globals
    local power_socket = 500 -- wallplug
    if (fibaro:countScenes()>1)
    then
    fibaro:abort();
    local run = 0
    local counter = 0
    local counter2 = 0
    local iron_on = 0
    local power=fibaro:getValue(power_socket, "power")
    if ( tonumber(fibaro:getValue(power_socket, "power")) > 2 ) and run == 0 then
    fibaro:debug("IRON IS ON...")
    fibaro:debug("consumption = "..power.." Watt")
    run = 1
    while run == 1 do
    if (tonumber(fibaro:getValue(power_socket, "value")) == 1) then
    counter = counter + 1
    if (tonumber(fibaro:getValue(power_socket, "power")) > 2) and counter > 360 then
    fibaro:debug("Iron is on after 30 mins")
    fibaro:debug("Send Push")
    fibaro:call(285, "sendPush", ">30 min. Iron is on!!!", "iron");
    iron_on = 1
    while (tonumber(fibaro:getValue(power_socket, "value")) == 1) do
    if (counter2 > 60) then
    fibaro:debug('Still on. Send Push');
    fibaro:call(68, "sendPush", "REMINDER >5 min. Iron is on!!!", "iron");
    counter2 = 0
    fibaro:sleep(5*1000);
    elseif (tonumber(fibaro:getValue(power_socket, "power")) == 0 and counter < 360) then
    fibaro:debug("Iron off < 30 min... Abort scene")
    run = 0
    counter = 0
    Guest fat
    Glad to have helped
    • "id": 68,
    • "roomID": 0,
    • "baseType": "",
    • "enabled": true,
    • "visible": true,
    • "parentId": 0,
    • "viewXml": false,
    • "properties": {
      • "Push": "true",
    • "actions": {
      • "sendPush": 1
    • "sortOrder": 64
    Thank you, found it.
    Only thing what worries me that I've got an Android device and also I get:
    "type":"iOS_device"
    Android phones have the same type as apple's. That is documented nowhere, I know it from experience.
