Virtual device for Daikin HVAC - command and get room temp
Hi there guys,
I have 3 Daikin HVAC air conditioners in my house, each unit has a wifi module that allows me to control it thru the iphone app from local and from remote...that works really fine and I found on the web all the APIs to control them from HTTP strings (GET and POST).
Now the question is...is there any way to create a virtual device in fibaro system for control them? (like sonos i think)...that would be really nice and it could even get room temp from the HVAC unit!!
APIs have found here
Guest chaicka
It's not that difficult.
Just need to know these:
f_rate represents the fan rate and not all Daikin model supports this
value desc
A auto
B silence
3 lvl_1
4 lvl_2
5 lvl_3
6 lvl_4
7 lvl_5
f_dir represents the fan direction and not all Daikin model supports this
value desc
0 all wings stopped
1 vertical wings motion
2 horizontal wings motion
3 vertical and horizontal wings motion
On 5/13/2016 at 1:20 PM, AlexFIB said:
Hi, your Daikin must have a fixed IP.
Then try this lua script in button on a virtual device:
local Daikin = Net.FHttp("192.168.1.31", "80") -- fixed ip of Daikin AirConditioner on lan
local a = {}    -- array
local b = {}    -- array
local parametri = ""
local uri = "aircon/get_control_info";
result, status, errorCode = Daikin:GET(uri)
-- fibaro:debug("result: " .. result)
-- fibaro:debug("status: " .. status)
-- fibaro:debug("errorCode: " .. errorCode)
if errorCode == 0 then
i=0
for valore in string.gmatch(result, '([^,]+)') do
     i=i+1
     a = valore
-- INFO of array and value of different parmeter
-- a[2] - pow=   [Valori 0=OFF | 1=ON]
-- a[3] - mode=  [Valori 2=DEHUMDIFICATOR | 3=COLD | 4=HOT | 6=FAN | 0-1-7=AUTO (standard valore 0)]
-- a[5] - stemp= [Range AUTO 18-31 | HOT 10-31 | COLD 18-33]
-- a[6] - shum=0 [0]
-- a[7] - dt1=   [Range AUTO 18-31 | HOT 10-31 | COLD 18-33]
  stemp = tonumber(string.sub(a[7], -4))
  a[6] = "shum=0"
-- Starting to change a parameter. Exp POWER ON
a[2]="pow=1" -- ON
  a[5] = "stemp=" .. stemp
-- End to change the parameter
parametri = a[2] .. "&" .. a[3] .. "&" .. a[5] .."&" .. a[6]
uri = "aircon/set_control_info?" .. parametri
fibaro:debug(uri) -- For debug
result, status, errorCode = Daikin:GET(uri) -- execution of the command
  fibaro:log("OK")
  else
fibaro:log("Command NOT executed")
else
fibaro:log("NO connection")
This example power on the air contioner
why don't work?
I have this message on debug
[ERROR] 22:28:43: line 26: bad argument #1 to 'sub' (string expected, got nil)
13 hours ago, alexbrz16 said:
why don't work?
Into your browser type: http://192.168.1.31/aircon/get_control_info
and if it works, do you read this message:
ret=OK,pow=1,mode=3,adv=,stemp=22.0,shum=0,dt1=25.0,dt2=M,dt3=22.0,dt4=25.0,dt5=25.0,dt7=25.0,dh1=AUTO,dh2=50,dh3=0,dh4=0,dh5=0,dh7=AUTO,dhh=50,b_mode=3,b_stemp=22.0,b_shum=0,alert=255,f_rate=A,f_dir=1,b_f_rate=A,b_f_dir=1,dfr1=5,dfr2=5,dfr3=A,dfr4=5,dfr5=5,dfr6=5,dfr7=5,dfrh=5,dfd1=0,dfd2=0,dfd3=1,dfd4=0,dfd5=0,dfd6=0,dfd7=0,dfdh=0,dmnd_run=0,en_demand=0
Look at the line 26 of your script and find the parameter that fault. For the example posted, correspond a[7] and the parameter is dt1: this parameter is not null.
Are you Italian?
I'm!!!
Edited by AlexFIB
Are you Italian?
I'm!!!
 Si italiano!
Ho guardato il parametro dt1 è impostato a 25
Hi, it's been a long time...
Can anyone post the latest working virtual device for Daikin?
Thank you :)
I cannot get this to work with the new Daikin units that use https.  They do not use the security features of https so it should be easy but the coding is beyond me.
I can Google how to do this in other home automation software (the one that has the initials HA for example) but when I try to code this in LUA I get no response from the unit.  I know HC has very flaky https implementation, it only works in scenes and then not always.  I assume this is the problem...
Anyone got any hints or tips?  I have already posted my code in this thread:
Edited by codowd
Hello everybody
i have a Daikin RXM35R air conditioning.
I can't communicate with her.
Do you have an idea?
the codes no longer work, i have the error:
[ERROR] 09:45:10: line 26: bad argument #1 to 'sub' (string expected, got nil)
I have its IP address 192.168.1.162.
when I go over it by chrome I have this as an answer:
This software is included following open source software.
The FreeRTOS kernel is released under the MIT open source license, the text of
which is provided below.
This license covers the FreeRTOS kernel source files, which are located in the
/FreeRTOS/Source directory of the official FreeRTOS kernel download.  It also
covers most of the source files in the demo application projects, which are
located in the /FreeRTOS/Demo directory of the official FreeRTOS download.  The
demo projects may also include third party software that is not part of FreeRTOS
and is licensed separately to FreeRTOS.  Examples of third party software
includes header files provided by chip or tools vendors, linker scripts,
peripheral drivers, etc.  All the software in subdirectories of the /FreeRTOS
directory is either open source or distributed with permission, and is free for
use.  For the avoidance of doubt, refer to the comments at the top of each
source file.
License text:
Copyright (C) 2017 Amazon.com, Inc. or its affiliates.  All Rights Reserved.
Permission is hereby granted, free of charge, to any person obtaining a copy of
this software and associated documentation files (the "Software"), to deal in
the Software without restriction, including without limitation the rights to
use, copy, modify, merge, publish, distribute, sublicense, and/or sell copies of
the Software, and to permit persons to whom the Software is furnished to do so,
subject to the following conditions:
The above copyright notice and this permission notice shall be included in all
copies or substantial portions of the Software.
THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND, EXPRESS OR
IMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES OF MERCHANTABILITY, FITNESS
FOR A PARTICULAR PURPOSE AND NONINFRINGEMENT. IN NO EVENT SHALL THE AUTHORS OR
COPYRIGHT HOLDERS BE LIABLE FOR ANY CLAIM, DAMAGES OR OTHER LIABILITY, WHETHER
IN AN ACTION OF CONTRACT, TORT OR OTHERWISE, ARISING FROM, OUT OF OR IN
CONNECTION WITH THE SOFTWARE OR THE USE OR OTHER DEALINGS IN THE SOFTWARE.
lwIP is licenced under the BSD licence:
Copyright (c) 2001-2004 Swedish Institute of Computer Science.
All rights reserved.
Redistribution and use in source and binary forms, with or without modification,
are permitted provided that the following conditions are met:
1. Redistributions of source code must retain the above copyright notice,
this list of conditions and the following disclaimer.
2. Redistributions in binary form must reproduce the above copyright notice,
this list of conditions and the following disclaimer in the documentation
and/or other materials provided with the distribution.
3. The name of the author may not be used to endorse or promote products
derived from this software without specific prior written permission.
THIS SOFTWARE IS PROVIDED BY THE AUTHOR ``AS IS AND ANY EXPRESS OR IMPLIED
WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE IMPLIED WARRANTIES OF
MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE ARE DISCLAIMED. IN NO EVENT
SHALL THE AUTHOR BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL,
EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT
OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS
INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN
CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING
IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY
OF SUCH DAMAGE.
mbed TLS
Apache License
Version 2.0, January 2004
http://www.apache.org/licenses/
TERMS AND CONDITIONS FOR USE, REPRODUCTION, AND DISTRIBUTION
1. Definitions.
"License" shall mean the terms and conditions for use, reproduction,
and distribution as defined by Sections 1 through 9 of this document.
"Licensor" shall mean the copyright owner or entity authorized by
the copyright owner that is granting the License.
"Legal Entity" shall mean the union of the acting entity and all
other entities that control, are controlled by, or are under common
control with that entity. For the purposes of this definition,
"control" means (i) the power, direct or indirect, to cause the
direction or management of such entity, whether by contract or
otherwise, or (ii) ownership of fifty percent (50%) or more of the
outstanding shares, or (iii) beneficial ownership of such entity.
"You" (or "Your") shall mean an individual or Legal Entity
exercising permissions granted by this License.
"Source" form shall mean the preferred form for making modifications,
including but not limited to software source code, documentation
source, and configuration files.
"Object" form shall mean any form resulting from mechanical
transformation or translation of a Source form, including but
not limited to compiled object code, generated documentation,
and conversions to other media types.
"Work" shall mean the work of authorship, whether in Source or
Object form, made available under the License, as indicated by a
copyright notice that is included in or attached to the work
(an example is provided in the Appendix below).
"Derivative Works" shall mean any work, whether in Source or Object
form, that is based on (or derived from) the Work and for which the
editorial revisions, annotations, elaborations, or other modifications
represent, as a whole, an original work of authorship. For the purposes
of this License, Derivative Works shall not include works that remain
separable from, or merely link (or bind by name) to the interfaces of,
the Work and Derivative Works thereof.
"Contribution" shall mean any work of authorship, including
the original version of the Work and any modifications or additions
to that Work or Derivative Works thereof, that is intentionally
submitted to Licensor for inclusion in the Work by the copyright owner
or by an individual or Legal Entity authorized to submit on behalf of
the copyright owner. For the purposes of this definition, "submitted"
means any form of electronic, verbal, or written communication sent
to the Licensor or its representatives, including but not limited to
communication on electronic mailing lists, source code control systems,
and issue tracking systems that are managed by, or on behalf of, the
Licensor for the purpose of discussing and improving the Work, but
excluding communication that is conspicuously marked or otherwise
designated in writing by the copyright owner as "Not a Contribution."
"Contributor" shall mean Licensor and any individual or Legal Entity
on behalf of whom a Contribution has been received by Licensor and
subsequently incorporated within the Work.
2. Grant of Copyright License. Subject to the terms and conditions of
this License, each Contributor hereby grants to You a perpetual,
worldwide, non-exclusive, no-charge, royalty-free, irrevocable
copyright license to reproduce, prepare Derivative Works of,
publicly display, publicly perform, sublicense, and distribute the
Work and such Derivative Works in Source or Object form.
3. Grant of Patent License. Subject to the terms and conditions of
(except as stated in this section) patent license to make, have made,
use, offer to sell, sell, import, and otherwise transfer the Work,
where such license applies only to those patent claims licensable
by such Contributor that are necessarily infringed by their
Contribution(s) alone or by combination of their Contribution(s)
with the Work to which such Contribution(s) was submitted. If You
institute patent litigation against any entity (including a
cross-claim or counterclaim in a lawsuit) alleging that the Work
or a Contribution incorporated within the Work constitutes direct
or contributory patent infringement, then any patent licenses
granted to You under this License for that Work shall terminate
as of the date such litigation is filed.
4. Redistribution. You may reproduce and distribute copies of the
Work or Derivative Works thereof in any medium, with or without
modifications, and in Source or Object form, provided that You
meet the following conditions:
  1. (a) You must give any other recipients of the Work or
    Derivative Works a copy of this License; and
  2. (b) You must cause any modified files to carry prominent notices
    stating that You changed the files; and
  3. (c) You must retain, in the Source form of any Derivative Works
    that You distribute, all copyright, patent, trademark, and
    attribution notices from the Source form of the Work,
    excluding those notices that do not pertain to any part of
    the Derivative Works; and
  4. (d) If the Work includes a "NOTICE" text file as part of its
    distribution, then any Derivative Works that You distribute must
    include a readable copy of the attribution notices contained
    within such NOTICE file, excluding those notices that do not
    pertain to any part of the Derivative Works, in at least one
    of the following places: within a NOTICE text file distributed
    as part of the Derivative Works; within the Source form or
    documentation, if provided along with the Derivative Works; or,
    within a display generated by the Derivative Works, if and
    wherever such third-party notices normally appear. The contents
    of the NOTICE file are for informational purposes only and
    do not modify the License. You may add Your own attribution
    notices within Derivative Works that You distribute, alongside
    or as an addendum to the NOTICE text from the Work, provided
    that such additional attribution notices cannot be construed
    as modifying the License.
You may add Your own copyright statement to Your modifications and
may provide additional or different license terms and conditions
for use, reproduction, or distribution of Your modifications, or
for any such Derivative Works as a whole, provided Your use,
reproduction, and distribution of the Work otherwise complies with
the conditions stated in this License.
5. Submission of Contributions. Unless You explicitly state otherwise,
any Contribution intentionally submitted for inclusion in the Work
by You to the Licensor shall be under the terms and conditions of
this License, without any additional terms or conditions.
Notwithstanding the above, nothing herein shall supersede or modify
the terms of any separate license agreement you may have executed
with Licensor regarding such Contributions.
6. Trademarks. This License does not grant permission to use the trade
names, trademarks, service marks, or product names of the Licensor,
except as required for reasonable and customary use in describing the
origin of the Work and reproducing the content of the NOTICE file.
7. Disclaimer of Warranty. Unless required by applicable law or
agreed to in writing, Licensor provides the Work (and each
Contributor provides its Contributions) on an "AS IS" BASIS,
WITHOUT WARRANTIES OR CONDITIONS OF ANY KIND, either express or
implied, including, without limitation, any warranties or conditions
of TITLE, NON-INFRINGEMENT, MERCHANTABILITY, or FITNESS FOR A
PARTICULAR PURPOSE. You are solely responsible for determining the
appropriateness of using or redistributing the Work and assume any
risks associated with Your exercise of permissions under this License.
8. Limitation of Liability. In no event and under no legal theory,
whether in tort (including negligence), contract, or otherwise,
unless required by applicable law (such as deliberate and grossly
negligent acts) or agreed to in writing, shall any Contributor be
liable to You for damages, including any direct, indirect, special,
incidental, or consequential damages of any character arising as a
result of this License or out of the use or inability to use the
Work (including but not limited to damages for loss of goodwill,
work stoppage, computer failure or malfunction, or any and all
other commercial damages or losses), even if such Contributor
has been advised of the possibility of such damages.
9. Accepting Warranty or Additional Liability. While redistributing
the Work or Derivative Works thereof, You may choose to offer,
and charge a fee for, acceptance of support, warranty, indemnity,
or other liability obligations and/or rights consistent with this
License. However, in accepting such obligations, You may act only
on Your own behalf and on Your sole responsibility, not on behalf
of any other Contributor, and only if You agree to indemnify,
defend, and hold each Contributor harmless for any liability
incurred by, or claims asserted against, such Contributor by reason
of your accepting any such warranty or additional liability.
END OF TERMS AND CONDITIONS
APPENDIX: How to apply the Apache License to your work.
To apply the Apache License to your work, attach the following
boilerplate notice, with the fields enclosed by brackets "[]"
replaced with your own identifying information. (Don't include
the brackets!)  The text should be enclosed in the appropriate
comment syntax for the file format. We also recommend that a
file or class name and description of purpose be included on the
same "printed page" as the copyright notice for easier
identification within third-party archives.
Copyright [yyyy] [name of copyright owner]
Licensed under the Apache License, Version 2.0 (the "License");
you may not use this file except in compliance with the License.
You may obtain a copy of the License at
http://www.apache.org/licenses/LICENSE-2.0
Unless required by applicable law or agreed to in writing, software
distributed under the License is distributed on an "AS IS" BASIS,
WITHOUT WARRANTIES OR CONDITIONS OF ANY KIND, either express or implied.
See the License for the specific language governing permissions and
limitations under the License.
JSMN is licenced under the MIT licence:
Copyright (c) 2010 Serge A. Zaitsev
Permission is hereby granted, free of charge, to any person obtaining a copy of this software and associated documentation files (the "Software"), to deal in the Software without restriction, including without limitation the rights to use, copy, modify, merge, publish, distribute, sublicense, and/or sell copies of the Software, and to permit persons to whom the Software is furnished to do so, subject to the following conditions:
The above copyright notice and this permission notice shall be included in all copies or substantial portions of the Software.
THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND, EXPRESS OR IMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES OF MERCHANTABILITY, FITNESS FOR A PARTICULAR PURPOSE AND NONINFRINGEMENT. IN NO EVENT SHALL THE AUTHORS OR COPYRIGHT HOLDERS BE LIABLE FOR ANY CLAIM, DAMAGES OR OTHER LIABILITY, WHETHER IN AN ACTION OF CONTRACT, TORT OR OTHERWISE, ARISING FROM, OUT OF OR IN CONNECTION WITH THE SOFTWARE OR THE USE OR OTHER DEALINGS IN THE SOFTWARE.
Eclipse Paho MQTT C/C++ client for Embedded platforms
Eclipse Distribution License - v 1.0
Copyright (c) 2007, Eclipse Foundation, Inc. and its licensors.
Redistribution and use in source and binary forms, with or without modification, are permitted provided that the following conditions are met:
Redistributions of source code must retain the above copyright notice, this list of conditions and the following disclaimer.
Redistributions in binary form must reproduce the above copyright notice, this list of conditions and the following disclaimer in the documentation and/or other materials provided with the distribution.
Neither the name of the Eclipse Foundation, Inc. nor the names of its contributors may be used to endorse or promote products derived from this software without specific prior written permission.
THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS" AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR CONTRIBUTORS BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
wpa_supplicant and hostapd
Copyright (c) 2002-2019, Jouni Malinen <[email protected]> and contributors
These programs are licensed under the BSD license (the one with
advertisement clause removed).
If you are submitting changes to the project, please see CONTRIBUTIONS
file for more instructions.
This package may include either wpa_supplicant, hostapd, or both. See
README file respective subdirectories (wpa_supplicant/README or
hostapd/README) for more details.
Source code files were moved around in v0.6.x releases and compared to
earlier releases, the programs are now built by first going to a
subdirectory (wpa_supplicant or hostapd) and creating build
configuration (.config) and running 'make' there (for Linux/BSD/cygwin
builds).
License
This software may be distributed, used, and modified under the terms of
BSD license:
met:
3. Neither the name(s) of the above-listed copyright holder(s) nor the
