Hi all,
I'm trying to install a Fibaro Light Dimmer into my office. I'm not able to do it right i'm afraid.
Does anyone know how to setup the dimmer with this configuration?
So, I have my office room with on 1 end of the room a switch and the other end of the room, also a switch.
See photo's attached. Anyone that can help me?
Thanks thanks thanks!
Greetz
You can try this connection.
    I'm afraid I can't do that because I don't have the "L" that needs to go into the dimmer?
    Loop from the L that goes into the switch? It's the same thing. You just have to give power to both the switches and the dimmer module.
