Hello
we have an Philips Fidelio wifi radio/loudspeaker.
I figured out that I can switch on the speaker bij simple Http commands like:
this switches on the radio preset 3.
is it possible to use a virtual device with 5 button to control the 5 presets and how?
thanks
Hi vloempie
I do not have fidelio, but this should work:
Make a new VD with IP and port of your fidelio. Create buttons for your presets and put code like this into each of them.
GET /nav$03$03$003$1
HTTP/1.10x0D0x0A0x0D0x0A
BTW. Do you have a HCL or HC2?
if you have LUA (HC2) you could try:
SrvVol = Net.FHttp("192.168.192.27",8889)
SrvVol:GET ("/nav$03$03$003$1")
Finally I found some time to play around with this partly useless audio player.
Attached is a VD for Philips Fidelio AW3000 (also compatible to other ones).
You can play mp3 files and radio streams.
Edited by Alex
Removed old version
Updated version
