I've purchased 5 fgs221 but one of these on the label is reported FGS222 (I know the new fgs222 and his aesthetic differences but this one is identical to 221).
Only this module on HCL has problem with default template... I can't see default template options as other 221's but only the label "parameters template will be added soon".
Antoher difference is the software version, the firsts 4 devices have 2.1 and this last 2.2
I can't understand where's the problem...
Attached the screnshots
I think the problem is exactly that, 2.1 vs 2.2. All templates are added based on version. Since the template might be different.
Do you mean that there is label on device with FGS-222 on it?
    My mystake... the module is a 221 with version 2.2
    but why the version 2.2 has no template? I should reset and include another time the device or should I wait Fibaro updates?
    There is no template, since the device was released after software for the controller. It will be added in future releases.
    • 3 weeks later...
    Hi, hope you all could help me with a problem I have with FGS222. I thought you could individual change the inputs to one to behave as a switch and one to be behave as a toggle switch? Ive tried to change the parameter 14 but it seems that you change it for boths inputs.
    It is not possible. And I am afraid this is a little bit OT
    /emoticons/default_smile.png" alt=":)" srcset="https://forum.fibaro.com/uploads/emoticons/[email protected] 2x" width="20" height="20">
    Thanks, j.nowacki, for your reply. OT=Off Topic? sorry for that.
    • 4 weeks later...
    Hi, I have bought two FGS222 and have the same problem with both. None of my old FGS221 modules have this problem.
    When I first include and set up the FGS222 it works fine. After a few hours, one of the two outputs turns on with no action from me and no scenes that control it. In the software both outputs still show as off, and turning the "always on" output on and off has no effect, this output will always stay on. I do not have any physical switches connected as the FGS222s are in a concealed location. The only thing I can do is reconfigure or reset the FGS222 which solves the problem for a few hours, then it starts again.
    My garden is flooding as one of the FGS222s is controlling an irrigation system!
