Best way to select all "lights"?
Most likely i am missing something obcious. But i would like to emulate the "all lights off" button on the tablet client in Lua.
Basically, i want to integrate that as one part of a larger "shut the house down for the night"-script.
change this code you will get all lights ....
You can even do it without the for loops.
Just request this:
  • Please login or register to see this code.
You can also do multiple type filtering:
The first filter is ? then the second or third is with an &
    Just request this:
    THat does not get all lights for me. The "all off" also kills my "Garden Lamp" etc. This selection does not find those.  (But i am thankful for the tip that you can filter the calls like this)
    Edit: Ok, but that made me realize that
    /api/devices?isLight=true should work.. And it did.
