Popup notification
Guest David86vm
Guest David86vm
While trying to use the Popup message box i first made an easy script which won't work :->
I set up a scene to turn on a light in de Bedroom, this works fine when pressing run light goes on.
Now I tried to make an Popup notification when selecting yes I should turn on the light trough scene 126 which does not happen.
Also I got 3 notification in the message box of the Fibaro App, who can not be removed and stay's the first 3 tries.
running on 4.049 and Iphone 5S ios 8.3 APP VERSION 2.5
below my code what's going wrong.
Code of popup scene:
%% properties
126
%% globals
-- variable containing path of Motion Sensor’s icon
local imgUrl =
-- pop-up call
HomeCenter.PopupService.publish({
        -- title (required)
    title = 'test',
        -- subtitle(optional), e.g. time and date of the pop-up call
    subtitle = os.date("%I:%M:%S %p | %B %d, %Y"),
        -- content header (optional)
    contentTitle = 'Light on?',
        -- content (required)
    contentBody = 'Turn on bedroom light"?',
        -- notification image (assigned from the variable)
    img = imgUrl,
        -- type of the pop-up
    type = 'Succes',
        -- buttons definition
    buttons = {
    { caption = 'Yes', sceneId = 126 },
    { caption = 'No', sceneId = 0 }
code light scene (ID 126):
%% properties
66
%% globals
local a = 1
  fibaro:call(66, "turnOn");
fibaro:debug("light on")
Who got those popup's working?
9 answers to this question
This couldn't work... Have a look at developer.fibaro.com...
Guest David86vm
    Removed the 126 from head block still won't work.
    I now just removed full scene and started over by copying the example of developer.fibaro.com only changed senceId to trigger my scene light in that scene  stay's off.
    Also got 15 message's in notification box which can't be removed.
    Does someone already have those popup's working and can provide an working example?
    Can you post your scene plz? I will have a look
    indeed post your code:)
    i have 15 of them running just fine.
    So there must be a syntax error
    one of my examples
    This scene is triggered by another scene so theres no trigger in this one
    Guest David86vm
    Just used code from the developer example and changed the sceneId to the one which should run after pressing "turn off"button.
    %% properties
    %% globals
    local imgUrl =
    -- pop-up call
        title = 'Brightness level',
        subtitle = 'is too high',
        contentTitle = 'Dimmer',
        contentBody = 'Would you like to turn it off?',
        img = '
        type = 'Critical',
        buttons = {
            { caption = 'Turn off', sceneId = 126 },
            { caption = 'No', sceneId = 0 },
            { caption = 'Set to 100%', sceneId = 0 }
    Guest David86vm
    After some time stop with the popup messages I'm still trying to get this working but without working result
    code I used
    when running scene 126 manual light goes on
    Also every time I press run the popup a get another popup in the app but can't remove them result 15 outstanding notifications
    Guest chaicka
    @Fibaro,
    Is there a way to remove the Popup Notifications in the bin?
    I have a test popup LUA scene and it works, generated two popup notifications but nothing happens when I click the 'Ok' button. And there is also no way to delete the notifications.
    Guest David86vm
    @Fibaro,
    So you actually have the same problem as me as far as I know there's still no solutions for this.
    @Fibaro please explain how to get the pop ups working right
    Hi guys.
    Sorry to open an old thread but did you ever find a solution to delete these notifications?
    I have 999+ notifications shown at the top and there's too many to delete!
    They are not sent to an individual so must be stored somewhere in the HC2.
    Thanks, Elton.
