parenthesis in graphic block programming,
Hello all!
Is there a way to put parenthesis in the condition of a scene?
I want different condition with OR and AND statement to trigger an action. In this scene,  i want the first block to trigger an action, or the combination of the other condition. How can i do it??
Thank you
7 answers to this question
Basically if you choose the condition in line it will be considered as they were in the same parenthesis, if the condition below it will be treated as another one. Like in the example below:
Hello
It is not very clear for me. I would like to create the following scene :
(timer day of week at 21:00 OR timer day of week at 22:30) AND Doors1 is closed AND Doors2 is closed AND temp < 19 THEN heating = ON
In the attached file, parenthesis are created for the AND whereas I need them for the OR condition
I think the scene will be run each day at 21:00 regardless the status of the door !!
How can I create the OR condition between parenthesis ?
I think what
means is you should insert an or function on the plus-sign right from the first red-time-block.
Then add the second red-time-block on the plus which appears on the right of the or function.
Basically one line always ends with a plus sign.
for example:
time-block or time-block +
and +
(block and block and block and block +)
then
block +
Thanks for your reply.
This want I understood. If that's true, that means parenthesis are not mandatory.
Because when I follow this procedure, none parenthesis is created for my first OR condition.
I will try again in a new scene and will informe you
Would be nice to have an option to put the parenthesis manually.
Exactly... There are many scenes I converted in LUA to add right parenthesis. Blocks were intented to be userfriendly and fast but we must use LUA only because of parenthesis !!!
Ok that's clear for me now.... after many tests
/emoticons/default_icon_wink.gif" alt=";-)" /> I understood the way it works after converting blocks scenes in LUA...
But it's too confusing parenthesis are not displayed in block scene whereas they exist depending of the way we add condition...
