in my lua i have a debug but instead of displayed it ones it displayed it three times
[DEBUG] 03:00:55: Lamps on 10%
s on 10%
what can i do
Would be nice to have the Lua to check whats wrong
What sonnyboy said, but please reduce the script to the minimum, leave out everything that works and is non essential. Reading someone else's code can be difficult and stripping it helps.
You can also try this at the beginning of your script:
If that helps, your script actually ran 3 times, when it produced those debug entries.
Were you able to solve your problem?
    i have debug it in a new if function and seporated it
    turnLightOn = function()
      for i = 1,#lamps do
        lightItems = lamps;
        if sunset == time90 or ((sunrise >= time90 and sunrise <=time75) and fibaro:getValue(eyeKeuken, "armed") == "0")
        then fibaro:call(lightItems, "setValue", lampValue10)
        elseif sunset == time75 or ((sunrise >= time75 and sunrise <=time60) and fibaro:getValue(eyeKeuken, "armed") == "0")
        then fibaro:call(lightItems, "setValue", lampValue20)
        elseif sunset == time60 or ((sunrise >= time60 and sunrise <=time45) and fibaro:getValue(eyeKeuken, "armed") == "0")
        then fibaro:call(lightItems, "setValue", lampValue30)
        elseif sunset == time45  or ((sunrise >= time45 and sunrise <=time30) and fibaro:getValue(eyeKeuken, "armed") == "0")
        then fibaro:call(lightItems, "setValue", lampValue40)
        elseif sunset == time30 or ((sunrise >= time30 and sunrise <=time15) and fibaro:getValue(eyeKeuken, "armed") == "0")
        then fibaro:call(lightItems, "setValue", lampValue50)
        elseif sunset == time15 or ((sunrise >= time15 and sunrise <=timeNow) )--and fibaro:getValue(eyeKeuken, "armed") == "0")
        then fibaro:call(lightItems, "setValue", lampValue60)
        elseif sunset == timeNow or (sunrise >= timeNow and fibaro:getValue(eyeKeuken, "armed") == "0")
        then fibaro:call(lightItems, "setValue", lampValue70)
    if (sunset or sunrise) <= time90
        then turnLightOn ()
    ------------------debuging------------------------------------------------------------------
        then fibaro:debug("Lamps goes on 10%")
        then fibaro:debug("Lamps goes on 20%")
       etc..................
    it works for now
