Dear All,
I've a problem with scene triggering.
I'm not able to find a solution.
The scene is ok. If I run it manually at 21:00 the virtual device button is pressed.
The scene doesn't start automatically.
Please help me.
Many thanks
7 answers to this question
You don't have any automatic trigger. What should trigger it automatically? the time only?
Can you try this:
    Nothing... It doesn't start.
    This is the code:
    Ok, this works... You need a function, which runs every minute to check the time.
    It works perfectly!
    I have others function inside the scene and all works fine!
    Thanks a lot!
    Giovanni
    No problem
