Remove a broken device from HC2/zwave
Apologies if this has been asked before, but i couldn't find the answer on the forum.
I have two broken zwave modules that i need to remove from my HC2.
I have read that if i press the remove button (X) on the device itself it only deleted the GUI component but not the zwave part of the device, is this correct?
How do i completely remove a broken module from my HC2, obviously devices->add/remove is not an option since the module is broken and does not respond anymore.
Thanks!
Peter
4 answers to this question
Deleting device by "X" removes it from HC2, not only from user interface.
    thanks for the quick response!
    So the difference between the X and the device->remove is that the last also 'unconfigures' the module/plug?
    Yes, deleting module by devices->remove, also removes module from the Zwave network globally. It means that you will be able to add it to the next Zwave network without reset. It will be like adding a brand new module.
    I have the same proble with a fibaro wall plug.
    ID 186: NOP sending succeeded. The device HAS not been removed. Please use Learning Mode to remove it.
    But the B button is broken so what can you do
