Need Virtual Device for Pioneer VSX 923
Hello everybody
I need a Virtual Device for my Pioneer VSX 923
I need the following buttons:
Power ON
Power OFF
Mute
Slider for volume level
Outputs buttons for all HDMI
Thank you for your help.
    POWER ON:
    %% properties
    %% globals
    fibaro:log("Start process");
    local _deviceIp = "192.168.1.200";
    local _devicePort = 23;
    local _maxRetryProcess = 2;
    local function _process(retry)
        retry = retry or 0;
        --open the socket
    local tcpSocket = Net.FTcpSocket(_deviceIp, _devicePort);
        --set the read timeout
        tcpSocket
    :setReadTimeout(250);
        --notify user
        fibaro
    :log("Try Power ON, #" .. retry .. " please wait...");
        fibaro:sleep(250);
    --send packet
    local bytes, errorCode = tcpSocket:write("\r\nPO\r\n");
        --check for error
    if errorCode == 0 then
        --cli should return the string sent if success
    local result = tcpSocket:read();
            -- could compare to the encoded version of the call to confirm success
        fibaro
    :log(result);
        fibaro:sleep(1000);
        return true;
        else
        if retry < _maxRetryProcess then
            fibaro:log("Retry process, please wait...");
            fibaro:sleep(1000);
            return _process(retry + 1);
        return false;
    local f, result = pcall(_process);
    if (f) then
        if (result == true) then
            fibaro:log("Command successufully transmited.");
        else
            fibaro:log("Cannot send command!");
    else
        fibaro:log("Error: " .. f);
    POWER OFF:
    %% properties
    %% globals
        retry = retry or 0;
        --open the socket
        tcpSocket
        --notify user
        fibaro
    :log("Try Power OFF, #" .. retry .. " please wait...");
        fibaro:sleep(250);
    --send packet
    local bytes, errorCode = tcpSocket:write("\r\nPF\r\n");
        --check for error
        fibaro
    :log(result);
        fibaro:sleep(1000);
        return true;
        else
            fibaro:sleep(1000);
        return false;
    if (f) then
        else
    else
