How to do 'like' comparator in LUA?
Hi All,
Simple question for those that know:
What's the most db efficient way to loop through ALL devices on an HC2 to pull out info on 'any' type of motion sensor that can be bought for an HC2? I only have two different types personally i.e Aeon (where type == 'com.fibaro.motionSensor') and Fibaro (where type == 'com.fibaro.FGMS001'). What other types are out there for other makes?
I want to do a bulletproof loop which will include 'any' Motion Sensor....what's the best way to do this without implicitly knowing the 'type' of each sensor? In my own code I simply implicitly look for those types but, where I to be making it for a disparate system (where I don't know what they have) what's the best way?Ideas much appreciated.
KR, Dave:)
PS As per title; if you know what a type is I would put == to but, if you know it 'contains' a word like 'motion' how can one code for, what I know as (in other languages) a 'like' comparator. e.g. loop where I find all motion sensors where type LIKE '%motion%'; i.e I don't care what's before it or after it as long as it has 'motion' in the type value.
s:find(pattern [, index [, plain]])
Find the first occurrence of the pattern in the string passed. If an instance of the pattern is found a pair of values representing the start and end of the string is returned. If the pattern cannot be found nil is returned.
just check if pairs are not null
    Thankyou kindly:)
